Classic Audi » Technical » Mech/Tech » Wheels & Tyres » p slots HELP
Old 28-01-10, 06:50 PM   #1
dandan
big gimping
dandan's Avatar
Default p slots HELP
anyone ever fitted p slots to an 80? what wheel bolts did you use? i thought the original 80 ones didnt stick into the hub enough so used the ones i bought for the orange rials, after reversing 3 inch i stopped due to clunking noise from the rear hubs/ can wheel bolts be to long help
dandan is offline   Reply With Quote
Old 28-01-10, 06:55 PM   #2
poss it's long bolts .jack up the rear only use 1 bolt and undo a bit at a time and see if the clonking goes
Old 28-01-10, 06:58 PM   #3
vag80
vag80's Avatar
it sounds like the bolts are to long and catching on the brake shoes,dose the wheel turn? you can buy the bolts in different
lengths you need to measure how much the original bolts threads stick out of the original wheel
hope this helps
200k club member
87-b3 80
83-4000 2 door
Old 28-01-10, 06:59 PM   #4
dandan
big gimping
dandan's Avatar
thatll be a job for tomorrow i was fannying around in the dark as it was,
Old 28-01-10, 07:28 PM   #5
3 solutions:
  1. Buy shorter bolts
  2. Buy 5mm spacers
  3. Get the grinder out and grind a few mill of the feckers!!
Old 28-01-10, 07:37 PM   #6
missfire
missfire's Avatar
a good tip that can save any cross-threading.......
put a nut, that fits, all the way on to the stud.....
grind the 'fecker'.......
as you take the nut off it will open up the threads again.....
its not my tip........an old guy told me.....!
Old 01-02-10, 12:43 PM   #7
had the same problem with mine so out the came the angle grinder...POWWWWEEERRR
