Classic Audi » Technical » Mech/Tech » Engine » Carb and jetting
Old 27-01-10, 08:50 PM   #1
Hloni
Default Carb and jetting
I have a '75, 80 GL which currently has a Weber fitted onto it.
1. How do l know the engine size?
2. How do l identify which Weber l have?
3. Which jets do l need?
4. How do l maximise economy?
Currently, fitted on her is a "pancake" filter. Should l attempt to find original?
Hloni is offline   Reply With Quote
Old 27-01-10, 08:58 PM   #2
vag80
vag80's Avatar
the engine should have the cc stamped on it or look at the log book, the carb should have it stamped on the side or a tag on it the carb should come jetted for the car if its the correct one for the car, the pancake filter is ok as long as you have an hot air feed from the exhaust to stop the fuel freezing in cold weather
200k club member
87-b3 80
83-4000 2 door
Old 27-01-10, 09:08 PM   #3
Hloni
This being a former student cab, when the uni books were removed, so where ALL the other books!
Have we no library on the forum with jetting guide perhaps?
carb for 1981 !!!! audi 80 1.6 no.worries Parts Wanted 4 25-01-10 08:42 PM
4 cyl carb manifold pimpdriver Parts Wanted 13 13-10-09 08:23 PM
carb engine running on pimpdriver Engine 3 09-09-09 10:09 AM
Carb mount betmasterx Engine 2 22-04-08 06:16 PM
