Classic Audi » Technical » Mech/Tech » Engine » 2.3 KV engine start problems.'91 Audi Coupe
Old 14-11-14, 05:00 PM   #1
Flying Frank
Flying Frank's Avatar
Default 2.3 KV engine start problems.'91 Audi Coupe
Have been trying to resolve this starting issue for a month or more now.
Problem is : FIRST start of the day , engage starter, engine fires and then..... IF the throttle is so much as dabbed, the engine stalls and will not re-start for a while ( flooded ? ) If the accelerator is not touched, the engine shudders along at about 450rpm , just "chugging" and if left , the accelerator may be VERY gently tickled/dabbed AFTER about 30 seconds.
Revs rise about 100rpm ....then after a few more dabs and by now about 50 seconds, the engine can be very gingerly accelerated up to about 1500rpm.....
After which there are no further starting issues for the rest of the day.
Have changed cold start valve and idle control valve plus both temperature senders on the block.( at least the water temp gauge works now! )
Running out of ideas.
Any ideas gratefully received.
PLEASE NOTE!!! My mistake, the engine is a NG code
Old 14-11-14, 05:06 PM   #2
Martc
Black Coupe Collector
Martc's Avatar
I have the exact same issue on my other CQ, which is in a very long list of things to do.
I am not one for replacing random parts, but I had a hunch it was the warm up regulator not working when cold so not getting enough fuel.
Take a look here from Mr Paynes site it might help.....
http://www.isham-research.co.uk/quattro/pressure.html
95 UrS6
87 Coupe Quattro
Old 14-11-14, 05:47 PM   #3
jamiecoysh
jamiecoysh's Avatar
metering head/fuel distributor fault
Old 14-11-14, 05:49 PM   #4
Flying Frank
that's the big expensive bit isn't it?
Old 14-11-14, 05:57 PM   #5
You say 2.3 KV ??
Is it not a 2.2 KV or a 2.3 NG
Old 14-11-14, 06:07 PM   #6
jamiecoysh
jamiecoysh's Avatar
yeah it is the big expensive part I had an 90 2.3e which had the same problem although it did it pretty much everytime it started.
Old 14-11-14, 07:36 PM   #7
Flying Frank
You say 2.3 KV ??
John, you are right and my apologies...it IS a 2.3NG !!! Getting my '85 cq mixed up with the '91 coupe.
Old 14-11-14, 07:44 PM   #8
That's not getting mixed up...that's showing off !
Have you checked the HT electrics? Ok it is probably an air/fueling issue but wouldn't do any harm to check dizzy cap and clean any crap from around the coil tower?........maybe check the resistance of the leads?
Old 14-11-14, 07:46 PM   #9
audizzz
This same problem has been experienced by other 2.3 audi owners including myself, we also replaced cold start valve, didn't work and after weeks of searching, it was fuel filters, there are hidden ones!!!!!!
Car had stood a while, fuel dropped quite low and pump manages to suck up and force through detritus from the tank. After thorough cleaning from the pump forwards, problem solved.
Somebody else on here may be able to locate other thread, worth a read.
audizzz is offline   Reply With Quote
Old 14-11-14, 07:52 PM   #10
Flying Frank
Definitely not showing off, there are too many seriously well informed guys on this forum with cars that are to dream of. My humble Coupe is supposed to be the daily driver but is driving me a bit crazy with the list of "snags" that never seems to get sorted.
Will give your suggestions a try tomorrow , weather permitting!!
