Classic Audi » Technical » Mech/Tech » Interior » how to remove aux guages in a coupe
Old 21-11-09, 12:23 PM   #1
c9eag
c9eag's Avatar
Default how to remove aux guages in a coupe
hey folks,
im almost done with all the small annoyin bits with the coupe, i think i might have a slight touch of ocd....... things like a small bulb not working really annoy me. any way i have eplaced the one in the dash that was out, sorted out the horn that wasnt working because of the change of steering wheel and replaced the bulbs in the heater controls as there was onlyone working but i have a bulb out on one of the aux guages that has to get done, i cant suffer it any more but dont know how to get into them
can any one help before i end up blanking it off with black tape lol
thanks
c9eag is offline   Reply With Quote
Old 21-11-09, 01:31 PM   #2
what about removing the gear stick surround and see if there are any hidden screws under there behind the ashtray?
or crow bar it
I thought you had got hold of a manual for that car?
Old 21-11-09, 01:47 PM   #3
FlyingDutchman
Just do it!
FlyingDutchman's Avatar
Originally Posted by c9eag View Post
hey folks,
thanks
I saw an article about this some time ago and will do my best to find it, I think it was on Audifans. seemed quite complicated, though.
FlyingDutchman is offline   Reply With Quote
Old 21-11-09, 01:48 PM   #4
c9eag
c9eag's Avatar
thanks mate, would be greatly appreciated
i've put a post on there as well so hopefully someone will point me in the right direction
Old 21-11-09, 03:00 PM   #5
Actually there isn't anything complicated
Remove that little plastic part which covers gap between gauges and center console - to do that, u have to remove cover of heater switches - pull all three knobs off, unscrew two screws, when cover is off, u will see two screws that holds that plastic piece in place. Next unscrew 13mm nut under rear ashtray and 8mm bolt which is under that little plastic cover next to handbrake. Remove gearstick knob, pull rearmost part [that one which is around handbrake] of center console a little bit rearwards, , switch in 4th gear, so gearstick is pointed to rear, pull gearstick's cover off, then pull that piece of center console up and away. When putting it back, be careful with clamps that holds it against dashboard.
It was, of course, for car equipped with heater/air con and MT, don't know anything about climate control and AT
Old 21-11-09, 04:57 PM   #6
c9eag
c9eag's Avatar
thanks dude, before i start do you know what bulb i need?
dont want to strip it down to find i dont have the bulb to replace it lol
Old 21-11-09, 05:27 PM   #7
As far as I remember the same as in center console switches and heater controls.
Old 21-11-09, 05:31 PM   #8
But maybe something like in speedo - actually I don't know, B4 have different VDO gauges than B3 I'm thinking about, despite they look almost identical. Just do it in time when shop is open and after removing all, go to shop, some missing interior parts will not affect speed of your coupe
Old 21-11-09, 05:47 PM   #9
FlyingDutchman
Just do it!
It seems as if you have your info, I nonetheless enclose the link to pics etc
Good luck
http://www.audifans.net/modules.php?...wtopic&t=15995
Old 21-11-09, 05:53 PM   #10
Can't see anything about VDO gauges, only speedo and heater controls
Headliner remove and refit vag80 Interior 7 10-11-09 09:35 PM
Trying to remove kv to fit aby quattropower Engine 0 27-03-09 09:23 PM
