Members: 19,783 | Total Threads: 40,092 | Total Posts: 471,093 Currently Active Users: 1614 (3 members and 1611 guests) Welcome to our newest member, Thank you very much for y |
hey, today forthe second time my brakes have started to stick on my 88 wr quattro, usually after being in traffic. if i leave the car around 15 mins, pump the pedal until its hard then start the car it seems to be ok....for a while. Aparently the master cylinder was changed to a BMW item just before i bought the car, bur sounds to me like a piston somewhere sticking. Any ideas??
many thanks Andy |
Had the same thing..felt like front brakes were pumping themselves on!.
![]() .sometimes go for a week or two without happening. Ended up swapping the master cylinder and was fine afterwards..needed new pads and discs though ![]() |
Brake master cylinder
Mr Sixty Thousand!!
Very commonly master cylinder, but bearing in mind it has been changed already, it's worth checking the balence bar used in the lhd to rhd conversion has not been adjusted up too far.If it has it removes the free play required for expansion. Worth also checking that none of the calipers are sticking. Quickest way is to use an ir thermometer onto the discs, if you don't have one, jack the car up after a short drive and see which wheel is tight.
http://www.oesems.co.uk/ |
I have also heard that the brake hoises can cause this they perish inside and stop the fluid returning correctly
#6 | |
I would drive down the motorway and the brakes were binding. Quick change of flexible hoses, and all was OK. Cheap too!!! |
Black Coupe Collector
Just did mine recently and it made a world of difference to the braking performance
95 UrS6 87 Coupe Quattro |
niceone thanks very much, will have a play soon as i get a chance, hopefully something cheap, anyone know a a rough price on a master cylinder? cheers, Andy
try pete reeve at qiuattro corner
still havent got round to doing this, but have found a bilstein/febi brand new brake pressure accumilator in the shed, worth trying?
| 200 20v rear brakes on a 200 10v ?? | Dave | Suspension & Brakes | 2 | 06-12-09 07:26 PM |
| later brakes on a type 85 | newt | Suspension & Brakes | 57 | 07-09-09 11:45 AM |
| Suspension&Brakes | capnjones | Suspension & Brakes | 1 | 01-08-09 06:23 PM |
| UFO brakes on Audi V8? | NBirkitt | Suspension & Brakes | 0 | 25-05-09 05:01 PM |
