Classic Audi » Technical » Mech/Tech » Engine » Auxillary air valve on 5 cylinder - Idle problem
Old 14-10-09, 10:55 PM   #1
Darron Edwards
Darron Edwards's Avatar
Default Auxillary air valve on 5 cylinder - Idle problem
I,ve recently had trouble with my tick over on my ur quattro. I checked and then changed the auxillary air valve but the problem still persisted. The tick over would be too low when cold and then too high when warm. No adjustment of the air screw would sort the problem so I checked the auxillary valve and found that it was only partially closing. I swapped the valve without success. I later found that there was a partially burnt out connection on the back of the fuel pump relay. Because the relay powers the aux valve and warm up reg, it was causing a current drop through to the warm up regulator and hence the auxillary air valve. Once I had cut the wire back and fited a new female spade connector, the correct current was reaching the heater element in the auxillary valve and resulted in the bi metallic strip operating fully to close off the air valve. She now ticks over perfectly.....I hope that this information will be of use to somebody.
Old 14-10-09, 11:47 PM   #2
Lofty
Lofty's Avatar
Thats interesting stuff.....Moneypit suffers from that niggle.....know where to look and investigate.
Old 15-10-09, 07:06 AM   #3
Darron Edwards
Exellent, I hope you fix it, Daz
Old 15-10-09, 02:54 PM   #4
This doesn't mean anything, as u found out
Old 15-10-09, 05:05 PM   #5
i had a split on the turbo to metering head hose which was causing me all sorts of running probs, its hidden away under the air box so not easy to find it.
Old 15-10-09, 05:47 PM   #6
Darron Edwards
Yeah, small faults are the hardest to sort out. On my car, because the aux valve was only closing 75%, tick over was still high, I did the old pinch test on the aux valve hose which told me it wasn't closing even though it would close when connected to a battery on the bench. Current drop was the culprit.
Old 15-10-09, 06:31 PM   #7
hmmmm iv got a tick over missfire on my old girl to ,it sounds like its droping onto four when ideling but a slight touch on the throttle to pick the revs up by a mere 150 rpm and it stops and back onto all five iv changed plugs leads dizzy cap and still no joy im thinking slight air leak but not sure as carnt hear air leak on booste , any ideas ?????????
john...
Old 15-10-09, 10:34 PM   #8
Darron Edwards
john...
Sounds to me like a slight air leak there John, have you checked the injector seals....spray some WD40 around em when the engine is running, if the engine note changes....its sucking in air there.
Old 15-10-09, 10:47 PM   #9
already beat you to that one darren had them out today to check if plastic inserts had unscrewed but no fine , iv checked for air leaks by presurising the system from elaphants trunk on but only used 3o psi from tyre so will try compreser on saturday , have considered low voltage as volt gauge in car only shows about 13 volts on tick over but iv got a spair aultinator , any thaughts ????
Old 15-10-09, 10:56 PM   #10
Darron Edwards
one other thing john, Check the connection on the fuel pump relay, you may have a voltage drop at the pump....just a thought.
Tags
tick over idle fault
ur quattro auxillary rad mounts Darron Edwards Engine 9 15-01-15 08:47 PM
Idle air control valve Micky Parts For Sale 0 18-09-09 09:22 PM
Idle Stabilization Valve Ringmaster Engine 2 21-08-09 03:45 PM
help with idle controll valve Micky Engine 7 17-10-08 04:25 PM
Idle stabilisation valve Micky Parts Wanted 17 03-10-08 07:41 PM
