Members: 19,743 | Total Threads: 40,088 | Total Posts: 471,063 Currently Active Users: 1097 (3 members and 1094 guests) Welcome to our newest member, Albertambug |
Right, the radiator on my Audi 100 quattro (2.3 NF engine, 1990 G reg) was leaking.
I have a spare off the same car (G reg, fitted with 2.5 litre Oettinger version of the NF engine). Here is my radiator: part no 443 121 251N ![]() Here is the radiator off the 2.5 part no 447 121 251G ![]() Putting the two together, they are slightly different. ![]() ![]() ![]() The overall sizes are the same (from the edge of the cowl to the water pipes), however on mine, the fan cowl included the contoured piece to fit inside the wing, and on the 2.5 one, the contoured piece is part of the radiator. However, if you look at the mounting holes they are offset on the 2.5 so if I fit that radiator, then it will be offset from where the mounting holes are on my 100. When I looked on ebay for replacement radiators, it seems that one should fit all 100s from 82-90 (ie. the Typ44 years) http://cgi.ebay.co.uk/Radiator-AUDI-...d=p3286.c0.m14 Shall I just try it and see, or get one of the radiators off my other 2 spare cars (NF auto, MC manual) And here: http://www.aaronradiator.co.uk/catal...tor-101-1.html they have the same radiator for all cars. Cheers Steve PS - msh - helpful replies only please! |
![]() Did u tried to fit it? It doesn't fit there? P.S. What is "2.5 litre Oettinger version of the NF engine"? |
oh how I love you msh! Just on cue.
I haven't tried to fit it, it just looks like it won't as the mounting bolts are offset. The 2.5 litre version of the Oettinger was in the car I got the radiator from quattrob81 on here. He bought the car on audifans.net and it was fitted from new with a 2.5 litre version of the NF engine. Scotts of Sloane Square in London I think the car was from. The engine looked the same as the NF (with the large 2 piece inlet manifold). He bought the car to put the engine in his Coupe quattro. Click here: http://www.audifans.net/modules.php?...ight=oettinger http://www.audifans.net/modules.php?...ight=oettinger |
The larger rad was from a car with air conditioning.
I have tried it in the engine bay, it fits. Just got to work out a way to fit the fan cowling as the lower nuts and bolts had siezed and the plastic broke off. |
For info
From vagcat.com (1990 100Q) 1 443121251P radiator / F >> 44-K-043 716 570MM / KU,NF (1) 443121251K radiator / F 44-K-043 717>> 615MM / (1) 443121251K radiator / for vehicles with heavy-duty water cooling system / and/or / trailer towing / and/or / air conditioner 615MM / I could not find 443 121 251N (also on my car) so I suspect was superseded by 443 121 251P. Similarly 447 121 251G could not be found either. 447 121 251H exists which is a 615mm one. As with most parts there are often small differences for no obvious reason. |
CHeers Ovalking.
I fitted the radiator tonight, off a 100 turbo. It is the 447 121 251G, but I used the fan cowling off the NF engine, as the turbo engine has a bigger fan with different electrical connections. Everything has gone back together, I just need to run it tomorrow and check it for leaks. I will post in a minute about the problem with the coolant light flashing. Cheers Steve |
<QUOTE>
Cheers Steve PS - msh - helpful replies only please![/quote] LMOA!!!....The Ambulance is on its way....I think my spleen has burst!! ![]() |
| changing radiator, Audi 100 2.3 | pimpdriver | Engine | 12 | 08-07-09 09:01 PM |
| Audi Coupe Gt / Quattro Radiator Complete With Fan | tony | Parts For Sale | 0 | 23-06-09 05:11 PM |
| radiator for my audi 80 1975!! | xXbullXx | Parts Wanted | 8 | 23-01-09 09:10 PM |
| Suspension woes | moomin | Suspension & Brakes | 2 | 28-03-08 09:11 PM |
