Classic Audi » Technical » Mech/Tech » Engine » Idle Stabilization Valve
Old 21-08-09, 10:03 AM   #1
Ringmaster
Ringmaster's Avatar
Default Idle Stabilization Valve
Hi all,
I think the ISV on my Avant's KU engine needs removing and cleaning.
I've never done this before and my Haynes manual is no use. Is it really a simple matter of just disconnecting the wiring at the connector and pulling it away from the rubber hoses?
I'm just wary of there being hidden pitfalls when doing this job.
Someone out there must have done this. Any tips will be appreciated.
Old 21-08-09, 12:18 PM   #2
Cornholio
Yes, just remove in the obvious way. Use carburetor cleaner to clean out the ISV
Cleaning out the breather hoses is a good idea too (while you have it apart), have a look here
http://www.kvquattro.com/techdocs/breather.html
and
http://www.kvquattro.com/breatherHoses.html
Cornholio is offline   Reply With Quote
Old 21-08-09, 03:45 PM   #3
Ringmaster
Ringmaster's Avatar
Thanks Cornholio
Auxillary air valve on 5 cylinder - Idle problem Darron Edwards Engine 12 16-10-09 11:08 AM
Idle air control valve Micky Parts For Sale 0 18-09-09 09:22 PM
Low idle and a whine Alfashark Engine 2 29-03-09 04:10 PM
help with idle controll valve Micky Engine 7 17-10-08 04:25 PM
Idle stabilisation valve Micky Parts Wanted 17 03-10-08 07:41 PM
