Classic Audi » Technical » Mech/Tech » Engine » ur quattro intake hose.......save money!!!
Old 31-07-09, 11:02 PM   #1
Darron Edwards
Darron Edwards's Avatar
Default ur quattro intake hose.......save money!!!
I have just saved a packet by doing an easy repair to my old and knackered intake hose on my ur. I don't know if anyone else has done this before but its saved me about a hunderd quid or so. My intake hose had split on the outside and was not too good on the inner sleeving so I went to look at the local scrapyard. i needed a pipe with 2.5 inch at one end and 2 inch at the other....simple you might think. After looking about, I found a LDV van with a hose that was a perfect fit at the 2.5 inch end, so I cut it to length, then I cut my old audi hose right down to the reducer sleeve but left the reinforcing wire inside of the sleeve, I then removed 25mm of reinforcing wire in the van hose and found that the end of the van hose fits very snugly indeed over the audi reducing sleeve, a jubilee clip holds the pipe securely in place. I'm well chuffed with it! oh, the pipe cost me 50p
Old 01-08-09, 01:16 PM   #2
its the same hose as on a mistro van and no cutting or reducing and pennys so im led to believe but that looks a bellter i do like a skilful bodge
Old 01-08-09, 01:23 PM   #3
nice one
well done that man
Old 03-08-09, 11:28 AM   #4
andy
andy's Avatar
my turbo-inlet manifold pipe blew a while back and as a temp fix, cut it before the bend (or T-piece) and connected one of an 90 degree T-piece off a tranny van, worked a charm ;-)
andy is offline   Reply With Quote
Save Money On Oils with club discounts oilman Parts For Sale 0 07-08-09 08:03 AM
WN carb and intake manifold. 4v6 Parts Wanted 0 19-01-09 09:55 PM
1982 80 CD Air intake random small pipe dav Engine 8 25-11-08 10:44 PM
WR engine intake quattrokid General Chat 2 16-08-08 08:43 AM
