Members: 19,782 | Total Threads: 40,092 | Total Posts: 471,092 Currently Active Users: 1604 (2 members and 1602 guests) Welcome to our newest member, DavidUsany |
Hiya
my gt5 coupe s 1986 does seem to have to much surface rust on the bodywork and arches. will it be a sensible idea to completly remove the bodyshell and replace it with one "spink" has. picstures of my car are on my profile may thanks |
You have your work cut out with this one, big job to swap body, though this is what needs sorting first before any mechanical stuf rectified.The body work is one (and virtually only) area I left to the experts. Good luck.
Ye I Sure Do....yes it is ..just waiting for quotes from various companies on replacing the rear wings...front left wing and also the a pillars.
any bodywork experts in here who may be able to help hehe yes i sure do need luck..and money:L:L |
Ahh, c'mon. You're talking like rust would be some kind of deadly sickness that can be removed only with heavy surgery
Cut that, cut that, weld that and pay a lot of money - why? Remove all rust to clean metal with, let's say, drilling machine with wire brush, apply some putty, grind it with sandpaper and colour it, using correct paint. Even when coloured with spray can, it can be unnoticable, if correct tone and techniques are used. On other side use some kind of bitumen or other anti corrosion treatment. If in cleaning process there forms some little holes, let's say, in 1 mm2 in size, that's nothing, putty will cover it. If there is hole something like 1 cm2, it can be patched, only looks like that it would be problematic to find someone who can do that ![]() |
hmm rust is a enemy...depends on how bad.....on ym a pillar and front left wing ..its abut 3inch holes in them:O....some of the smaller ones can be repaired with putty and the likes. need help from a garage in sorting the larger and worse damage to the bodywork though
#6 | |
| type 85 cq shell | s2rob | Parts For Sale | 4 | 29-01-13 09:10 AM |
| B2 80 + quattro shell the same | bandit1 | Bodywork, glass & exterior fitments | 15 | 29-01-10 09:41 PM |
| Audi 100 quattro body shell with caged | Audi Derek | Cars For Sale | 0 | 15-11-09 08:34 PM |
| CQ running gear in to a UR shell? | Gaz | Transmission | 3 | 11-02-09 12:03 PM |
| UR quattro rolling shell? | Gaz | Cars Wanted | 5 | 08-02-09 04:10 PM |
