Classic Audi » Technical » Mech/Tech » Electrical problems » ignition switch swappage on t85
Old 19-06-09, 02:57 PM   #1
spink
Default ignition switch swappage on t85
To save me taking the car apart and having it immobile does anyone know if the switch can be removed from the steering lock assembly?or do you have to take the barrel out and swap it into a good one?
Old 19-06-09, 05:35 PM   #2
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
you can change the switch on the back of the lock barrel. Not too bad a job.
http://www.oesems.co.uk/
Old 20-06-09, 03:05 PM   #3
spink
thanks Darren
Old 21-06-09, 11:22 AM   #4
steveb
steveb's Avatar
If you just want to see if the switch is faulty you can take the cover off pull the connector of the switch and plug it on the new one turn with a screwdriver. of course you still need the key turned on the old one to release the steering lock
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
A4 ignition switch part number 20vcqdriver Technical Info 9 31-08-09 09:30 PM
ignition switch Audi q 200 turbo bart simpson General Chat 6 20-07-09 06:12 PM
ignition switch bart simpson Parts Wanted 0 14-07-09 02:56 PM
Ignition switch vag80 Technical Info 2 24-06-09 06:17 PM
