Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » cq sunroof rubber seal
Old 15-07-09, 05:57 PM   #1
irish80sport
irish80sport's Avatar
Default cq sunroof rubber seal
just got my cq, but it needs a few bits and pieces, most important is i need a rubber seal for the sunroof, my car arrived without one! would audi still have them or do i need to look for a second hand one?
irish80sport is offline   Reply With Quote
Old 15-07-09, 06:25 PM   #2
spink
audi still sell them(well they did when i enquired around 6 months ago),something like £50 from memory
Old 15-07-09, 07:06 PM   #3
Yes they do and you are correct spink
Old 15-07-09, 09:00 PM   #4
irish80sport
great, il order one tomorrow, i hope they have them little bits of plastic under the drivers headlight aswell. and the front towing eye cover i hate having to look for bits.
Old 15-07-09, 09:02 PM   #5
irish80sport
is it correct that the same rubber seal would fit from a ur quattro? and my winder only puts the roof up and down, do they not slide backwards????
Old 15-07-09, 09:41 PM   #6
86audicoupe
Classic Audi Pervert!
86audicoupe's Avatar
The plastic strips under the headlights are best bought on eBay or from someone on here! It's doubtful they still make them to be honest (I may be wrong!). The sunroof should tilt up and down and be removable (two pins either side that you pull when roof is up). Sunroof slides into rack in the boot! Unless of course you have an aftermarket sunroof?
Old 16-07-09, 12:12 AM   #7
irish80sport
thanks for the info, its a factory sunroof, i just always presumed when a company would go to the bother of a winder it would slide back aswell, surely a pop up would have been easier?
Old 16-07-09, 12:38 PM   #8
MikeNZ
It is not rubber, and it is not actually a seal.
It is a sort of felt/flocking finish, and it is not actually designed to keep the water out.
Audi does them for £50-odd - well they did in Oct 08 when I bought one.
Type 85 sunroof seal ian20v Parts Wanted 8 04-02-10 06:55 PM
type 85 90q n/s rear quater window seal/rubber buck Parts Wanted 4 13-12-09 10:25 PM
Sunroof seal for 100 coupe S Coxy Parts Wanted 15 20-05-09 03:56 PM
Sunroof Seal 86audicoupe General Chat 4 10-03-08 07:40 PM
