Classic Audi » Technical » Mech/Tech » Engine » 20Vt trouble
Old 25-03-09, 08:15 AM   #1
20vcqdriver
20vcqdriver's Avatar
Default 20Vt trouble
Well after standing for 5 months, started the old beast up after the usual plugs out and wind over to get oil round to get pressure, then started her up and left to idle for a minute and then went to reverse the car out and as soon as I opened the throttle she stuttered and almost died, some blipping the throttle brought the revs up and so long as I did not shut the throttle engine kept running and managed to reverse out onto the drive. Once warm the problem virtually disappeared but on starting from cold the issue returns. Not been out on the road as no tax yet, but wondering if anyone on here can mention some ideas and see if you come up with the same conclusion. New hoses and clamps fitted from turbo to engine during charge cooler install and majority of Vacuum lines replaced with silicon equivalents too, so do not think I have an induction leak. Was hoping for a trouble free start to this years quattro driving...
Old 25-03-09, 08:48 AM   #2
Puglife
==>PUGSPORT!<==
Puglife's Avatar
What is there in the form of idle sensors or stabilisation valves? Possibility it could be that, or another possible problem area would be the Idle switch on throttlebody.
Old 25-03-09, 09:37 AM   #3
20vcqdriver
Car idles fine, it is when you come off the throttle switch that things get unstable. Will tick over smoothly all day... present suspect is the MAF but this was changed last year (admittedly for a 2nd hand one) and do not wish to spend a fortune on a new one if there is something else at fault I have not thought of.
Old 25-03-09, 04:05 PM   #4
fault codes should be the first port of call.
I'd be inclined to suspect a good run may see this sorting itself.
1991 90 quattro
Old 25-03-09, 06:31 PM   #5
4v6
I suspect a series of test pilots may be willing to perform such a service....
Hope you get it sorted asap.
Old 25-03-09, 06:35 PM   #6
martinjs
Could be the maf, try it with it disconnected.
1992 UrS4
martinjs is offline   Reply With Quote
Old 25-03-09, 07:13 PM   #7
dynamodav
How about drive it around for a little while and see if it fixes itself, you did just start it up after 5 months.
dynamodav is offline   Reply With Quote
Old 25-03-09, 07:40 PM   #8
20vcqdriver
Further developments... Took a chance and drove it 1/2 mile down the road once it had warmed up. CAr is only boosting to mechanical boost of 0.4bar. Not sure if a faulty MAF would cause this or if I have some other unknown issue. Was also making an unusual whooshing noise as I opened the throttle. Doh! No sign of an air leak but they can be a b***er to find...
Old 25-03-09, 08:31 PM   #9
quattroamm
Hi, can you give some details as to which chargecooler you have used and where it is fitted, thanks.
quattroamm is offline   Reply With Quote
Old 26-03-09, 10:50 AM   #10
20vcqdriver
No Probs. See pics. Had to modify it mind you as I wasn't happy with the cooling arrangements with only the centre getting most of the water so as ever I modified it.
It appears I have a mammoth boost leak on the inlet manifold Though trying to find it is turning into a mare of a job. Going to try and borrow a boost leak tester from Tim C.
CGT Ignition/engine trouble/Solved ZermattGT Engine 14 04-02-10 11:10 PM
porsche I5 20vT andy General Chat 9 08-11-09 05:58 PM
1.8 20VT questions b2_sport Engine 15 19-04-09 11:21 AM
audi 80 1975 carb trouble!! xXbullXx Engine 10 11-12-08 08:11 AM
Now Coxy's in trouble. Grizz General Chat 2 23-09-07 08:45 PM
