Classic Audi » Technical » Mech/Tech » Engine » Flaming!? is it safe?
Old 23-03-09, 02:03 AM   #1
Gaz
Gaz's Avatar
Exclamation Flaming!? is it safe?
It seems according to my m8s following me at the weekend that my cars exhaust flames!
Cool as it is.. Should I be worried? Is there any chance I could blow a big hole in my system?
I'm guessing its doing it because of the missing cylinder at low rpm.. Its like a gun going off when it pops! I heard a girl even scream when it happened last night as i drove thru town past some fittys! lol
Old 23-03-09, 07:23 AM   #2
Daveymaclad
Daveymaclad's Avatar
My very first CQ did that, bubbled a lot and I only realised it flamed when a friend of mine was following me! Mine was caused by a shitty replacement exhaust from the devil (euro car parts). In my experience, aside from some shocking fuel economy (due to the amount of unspent fuel you're forcing through the system) I don't think it's immediately worried!
However I'm not sure how your local constabulary will think of it if they see it, or your MOT test station when that time comes!
Old 23-03-09, 08:26 AM   #3
As stated really, don't think it's too much off an issue as the 'flame' only really gets going beyond the tailpipe as more air becomes available. Our Ur belches flame so big sometimes you can see it in the rear view mirror, over the top of the bootlid spoiler. And I'm not making that up, there's several people on the quattroforum that have witnessed it. The exhaust has never been damaged, and neither has any rear trim. It's quite rare for a standard KV to get angry, but you're running something a little bit more 'special' so, even when running right, you might get a bit of bad behaviour like that.
Old 23-03-09, 08:44 PM   #4
Gaz
Gaz's Avatar
burbles and flames??? sounds like a good exhaust to me! lol
As for the fuel economy at the moment while missing a cylinder.. CHRIST!... its really bad. its Lucky I work at a petrol station, or i might not get home after my shift!
Old 23-03-09, 10:01 PM   #5
Because you are running what is effectively mechanical fuel injection and the engine has no knock sensors controlled by an ECU, the cylinder keeps fueling and as it's not getting ingnited goes straight down the exhaust. Then becuase of the hot exhaust and highly flammable gasses, voila.....flames. You can of course 'help it along a bit' but me and Simmo will tell you how another day. You do need to get it fixed though as some of the fuel may wash the bores a tad if your rings are worn slightly
Old 24-03-09, 12:27 AM   #6
Gaz
Gaz's Avatar
When you say 'wash the bores' what do u mean? Is that bad?
Old 24-03-09, 05:49 AM   #7
Alfashark
Alfashark's Avatar
Bad indeed mate, unburnt fuel is a great degreaser.... as such it can wash off the thin film of oil spread over the cylinder bores by the rings every time the piston moves up and down... metal on metal = scratched bores/damaged rings.
Alfashark is offline   Reply With Quote
Old 24-03-09, 08:54 AM   #8
86audicoupe
Classic Audi Pervert!
86audicoupe's Avatar
I get a lot of backfire and flames but this is through the side exit. Suppose it's a bit different though as the car is running fine but there's unburnt fuel/different back pressure when running with no silencers.
Old 24-03-09, 09:57 AM   #9
And with a fully 'boxed' exhaust system the whole little cacophony and vollys of bangs pops and rasps and farts gets mightily subdued to.............next to nothing. The boxes add as a fantastic heat soak too.
Just when you thought it was safe...... Booty General Chat 3 05-01-10 10:02 PM
Radio -SAFE-?? Coxy In-Car entertainment 27 01-07-09 06:27 PM
