Classic Audi » Technical » Mech/Tech » Wheels & Tyres » outside tire wear? :(
Old 29-03-09, 09:45 PM   #1
Gaz
Gaz's Avatar
Unhappy outside tire wear? :(
both front tires on my CQ are wearing on the outside.. yet still have plenty of tread left on the rest of the tire.
Whats wrong? or is that normal?
My rear tires on the other hand seem to be wearing evenly.
Old 29-03-09, 09:47 PM   #2
4v6
Could be excessive toe in or incorrect camber... have the alignment properly checked id reckon.
Old 29-03-09, 09:57 PM   #3
yep 4x4 alignment needed
Old 29-03-09, 09:58 PM   #4
Ditto... Camber
Old 29-03-09, 10:04 PM   #5
Puglife
==>PUGSPORT!<==
Puglife's Avatar
got this on passenger side front tyre.... known toe out and incorrect camber...
Old 05-04-09, 08:42 PM   #6
MikeNZ
Needs to be done annually.
Old 05-04-09, 10:22 PM   #7
I would agree, service etc and 4x4 alignment
Old 05-04-09, 10:25 PM   #8
Sie!
What would cause it on a rear tyre, same?
I have tyre wear on the outside of my rear left, but not right...
I have just had new wheelbearings fitted, would this help combat it?
Sie!
Sie! is online now   Reply With Quote
Old 07-04-09, 02:05 AM   #9
MikeNZ
Unlike the quattro suspenion, the Type 85 FWD suspension is not adjustable at the back - it is a beam axle like Golfs.
The quattro rear suspension on a Type 85 is almost the same at the rear as it is at the front, so it is adjustable, and needs to be aligned along with the front.
Knackered bushes can still allow uneven tyre wear even with correct alignment as the excessive free play will allow the wheel to be improperly positioned when the suspension is under load (e.g. cornering).
In your case with a FWD car, it could be knackered bushes or perhaps damage if the rear axle has been heavily kerbed or the car has been in an accident. My money would be on the rear axle bushes, even if they pass the MOT they could still be deflecting excessively under load.
Old 07-04-09, 08:40 AM   #10
That reminds me, another cause of rear beam damage is the old girl being jacked up on it at tyre service 'establishments'... Watched some prat try that with my old GT, damaged the panhard Rod too.
a 185/50/16 tire and a 195/45/16 tire Gaz Parts Wanted 0 02-09-09 11:29 PM
what watch do you wear? pimpdriver General Chat 66 25-04-09 05:44 PM
195 60 14 tire Gaz Parts Wanted 1 23-07-08 08:14 AM
