Members: 43,046 | Total Threads: 40,085 | Total Posts: 471,036 Currently Active Users: 1587 (2 members and 1585 guests) Welcome to our newest member, Floydtup |
http://www.sealtd.net/quattro/ishamr...rent-lead.html
Morning! Anybody know the exact wiring layout for one of these? Is it just a split in the positive side bridged by a multi-meter set to read current? Thanks! |
Yes, at least that's how I did it. The original lead was looking a bit old anyway, so I soldered in a longer lead and tried to get the idle right while the bare wires were accessible. I also bought a cheap Chinese rev measuring gauge to get an accurate RPM. You wrap a fly lead around the main HT lead. (this kind of thing from eBah Digital LCD Engine Hour Meter Inductive Tachometer Gauge For Car Boat Motorcycle ) It gives various ways to take the reading for 4/6/8/12 cylinder engines.... IIRC, the numbers I was looking at for around 900RPM were around 4500. So it was obvious I had to divide by 5. Those numbers may be wrong-its been a while-but the "divide by" number is obvious once its set up. (EG if it reads 4500 and is idling just a little slow, its not "divide by 4" to give 1125RPM, or divide by 8 to give 562.)
2014 S3 (daily drive) 1987 MB ur Last edited by BackintheFold; 22-02-24 at 10:24 AM. |
Well, my NG engine (1992 Cabrio with 2.3E KE-Jetronic) also have this gizmo. It's ON/OFF, nothing is really spinning inside.
Actually there are two different types. The one I have is a piston that open or shuts longitude wise to allow more or less air through the ISV, the other type has a turning valve that does the same - still an ON/OFF valve. I had issues with failing idle at lift-off. Resolved it by putting the ISV in a bag with brake cleaner and a good shake and left to soak 10 minutes. Cleaned it all out with plenty WD40 and a full squirt of sewingmachine oil. Car has done 330.000 km and has done 210+ km daily since October 2023. Runs about 16 km/l mixed city/motorway. |
Thanks guys, I’ll bodge something up
