Classic Audi » Technical » Technical Info » part number for fuel pump relay
Old 27-03-09, 08:31 AM   #1
Fitzy
Default part number for fuel pump relay
for my 100 c.s its got a mickey mouse one in there causing my non start (well i thinkits the fuel pump relay !!?) as its not labelled and its not in the manual!!
but it does look like an after market one
reg is e690ybw
hope u can help
thanks
Fitzy is offline   Reply With Quote
Old 27-03-09, 08:57 AM   #2
eltee
eltee's Avatar
part number is 443907385F , relay location 10 on the fuse board under the bonnet, make sure the fuse box lid is tight on, or water from the windscreen runs onto the fuse board and causes all sorts of problems.
retail price from Audi is £61.99 including vat, and they have 3 in stock at Audi, but you may find a second hand one as they were fitted to the likes of golf gti's just check the numbers on top.
not sure if you can get non genuine, but may be worth a try.
eltee
88 100 cs sport
Old 27-03-09, 02:50 PM   #3
Fitzy
o.k thanks very much for your help mate
Need a Fuel Pump relay 1983 CGT (FI) ZermattGT Parts Wanted 8 20-01-10 10:00 PM
Coupe quattro kv alternator or part number Shaun1706 Parts Wanted 7 08-01-10 10:13 PM
A4 ignition switch part number 20vcqdriver Technical Info 9 31-08-09 09:30 PM
Part number for audi 100 wheel bearing? Scarlet Technical Info 14 28-03-09 03:07 PM
Clutch Cable - Part Number? Sie! Technical Info 7 28-07-08 11:12 PM
