Classic Audi » Classifieds section » Parts Wanted » PAS Vane Pump MB ur quattro, or rebuild kit?
Old 19-10-21, 09:39 AM   #1
BackintheFold
BackintheFold's Avatar
Default PAS Vane Pump MB ur quattro, or rebuild kit?
Hi
I am looking for a new/replacement pump, or failing that a rebuild kit. Mine has a slight leak.
Any advice on where to get one much appreciated!
I think the part number i need is 034145165 (for the pump).
Thanks
2006 A3 (daily drive)
1987 MB ur
Old 19-10-21, 01:36 PM   #2
you could be in luck. I'll check the garage
Old 19-10-21, 01:44 PM   #3
BackintheFold
I wish i had a garage like yours!!
Thanks Mike.
1987 MB ur
Old 19-10-21, 05:30 PM   #4
SorenR
SorenR's Avatar
Rebuild ... Gasket set is peanuts compared to new'ish pump and it takes 10 minutes longer compared to just swapping the pump...
Pump is from Cabrio 2.3E, gasket set is for other type pump than LUK. Audi uses two types of pumps ... 50% chance of getting the right one ... Failed that ;-)
SorenR is offline   Reply With Quote
Old 19-10-21, 07:05 PM   #5
The MB uses a tandem pump, not a vane type pump.
I've sent you a message Stuart
Old 19-10-21, 08:12 PM   #6
SorenR
SorenR's Avatar
As I wrote. Audi use two different pumps. In my case with the Cabrio 2.3E - some have the tandem pump and some have the vane pump. Notice the picture, pump is vane type and gasket set is tandem type. ;-)
Old 20-10-21, 08:07 AM   #7
Part number for the rebuild kit is iirc: 026 198 049B.
Anywhere from 6 to 16 quid.
Old 20-10-21, 03:09 PM   #8
SorenR
SorenR's Avatar
There are two different types...
035 198 049 A
https://www.ebay.com/itm/362533347161
026 198 049 B <== This is the one for my LUK pump and also most Mercedes models.
https://www.ebay.com/p/671155714
