Classic Audi » Technical » Mech/Tech » Engine » 2.2 B2 Quattro Sport tuning?
Old 03-03-09, 08:16 PM   #1
Kit
Kit's Avatar
Default 2.1 B2/Type 81 Quattro tuning?
Hi there, i'm going to be starting a restoration thread within the next month on an A reg B2 Quattro.
I was hoping someone could recommend either a good tuner, or what I can do to get the car running at optimum power (cams...etc).
I'm rebuilding the car the the ground up for hill climb, budget for the engine is circa 1000-2000.
Kit is offline   Reply With Quote
Old 03-03-09, 10:16 PM   #2
Kit
Kit's Avatar
Cams: Schrick 272
Induction kit: Performance air filter and Ur quattro airbox
Need recommendations for:
Exhaust (manifold/header, center, backbox): ?
Porting/gas flowing head: ?
Spark Plugs and HT leads: ?
Oil pump: ?
Old 03-03-09, 11:24 PM   #3
Originally Posted by Kit View Post
Cams: Schrick 272
Oil pump: ?
for all of the above, speak to Tony (4V6), or Simmo or Booty or (Jay) Puglife!!!!!!!!
Old 03-03-09, 11:42 PM   #4
Kit
Kit's Avatar
for all of the above, speak to Tony (4V6), or Simmo or Booty.
cheers i'll send them all a pm now
Old 04-03-09, 12:15 AM   #5
Puglife
==>PUGSPORT!<==
Puglife's Avatar
Keeping stock KV lump I'd suggest ditching the k-jet and going for stand alone management, you'll need an EFi conversion kit to do this (fuel rail, electronic injectors).
The cam will aid performance further up but remember with hillclimbing you want low down power too....
Torque will be your friend here.... Sadly budgets limiting on what you can achieve, but my suggestion would be tubular equal length exhaust manifold and ITB's with long runners and 45mm intakes. This will give good torque and i'd hazard a guess mixed with EFi push the engines potential alot higher. Be wary of heatsoak though as its not a crossflow engine so i'd suggest a heatshield between exhaust and intake runners and a good cold air feed from inner wing...
As a guess:
EFi conversion - £700+
ITBs - £600 ( Colin satchell down in devon is the man for this task)
Shrick cam - £350
Thats £1700 or thereabouts.... The head porting will help abit but again be very careful with this.
Old 04-03-09, 12:21 AM   #6
Kit
Kit's Avatar
Who would I buy the EFi kit off, or would I have to get the parts from anothermodel, if so, which model is best to pilfer them from?
Also, wholm can I get an equal length exhaust manifold from?
1.8 DZ tuning b2_sport Engine 9 16-09-09 10:31 PM
DS Tuning Dannny Engine 10 27-07-09 09:31 AM
K-Jet tuning b2_sport Engine 4 18-06-09 11:22 AM
2.2 B2 Quattro Sport tuning? Kit Suspension & Brakes 3 04-03-09 12:54 AM
