Classic Audi » Technical » Mech/Tech » Engine » electric turbo water pump thing.
Old 21-09-10, 09:21 PM   #1
missfire
missfire's Avatar
Default electric turbo water pump thing.
hello
electric water pump mc11 engine
does anyone know an easy way to test this thing.?? is there a temp sensor related to it and it only? or is it run from the ecu..?
not heard it running yet...but have not been ripping the car around yet either so maybe it has just not been needed..?
thank you
Old 21-09-10, 09:25 PM   #2
usual test is bridge the after run sensor wires together.
The fan will run at #1 speed and the electric pump should also run. You may need to put your hand on the pump to feel it running as it's very quiet. So obviously do this on a cold engine
Old 21-09-10, 09:27 PM   #3
missfire
missfire's Avatar
thanks
