Members: 43,040 | Total Threads: 40,085 | Total Posts: 471,034 Currently Active Users: 886 (7 members and 879 guests) Welcome to our newest member, JeffreyDot |
I've got a weeping gasket-and replacements seem to be expensive for a tiny gasket.
I know I can buy sheets of gasket material for a few quid off eBay, and I've looked at many listings but I don't know the exact material I should use, or the thickness. So the question is does anyone know the spec of gasket material and thickness please? Also, the torque setting seems to be 25nm. This sounds pretty high for two small Allen key bolts, and I got scared as i started to tighten mine so didn't get close to that. The RR engine spec shows th torque needed as 10nm, and the bolts appear the same!! So another question is can someone please confirm I'm getting this right and I should tighten to 25 or 10Nm? The oil hose is number 12 on 7zap...and the bolts are 13 Thank you! https://audi.7zap.com/en/rdw/audi+qu...aqs/1988-46/1/ Last edited by BackintheFold; 21-04-19 at 08:26 PM. |
I think I may have one of these since it's the same one used on an S2. I'll pop it in the post for you
There's no way an M6 bolt gets tightened to 30Nm - they will break. 10Nm for an M6 - I don't know of any exceptions to this. A WR uses an M8 bolt in this location which is possibly where your're seeing 30Nm.
#3 | |
2-the torque values are on Phil Payne's site. Shown as 10v at 25Nm, 20v as 10Nm. NB. No distinction made for WR and MB engines. 3-interestingly, the 7zap diagrams are wrong for the turbo. They show wr 1982 turbo chargers as being water cooled. 4-there is no 4 5-will be nice to stop the weeping, then I can put my undertrays back on. |
