Classic Audi » Technical » Mech/Tech » Engine » Audi 80 Sport - J reg
Old 01-01-09, 09:15 PM   #1
moomin
Default Audi 80 Sport - J reg
Need some help with that bargin "£90" 80 sport I purchased.
Starts and idles fine.
Under acceleration it begins to drop off the revs like a misfire.
Once it's warm the idle bounces between 900-1100 rpm and after a while longer the engine turns off.
What do I need to replace to make it go forward again?
Adam
moomin is offline   Reply With Quote
Old 01-01-09, 11:31 PM   #2
Cheap stuff 1st:
plugs
leads
dizzy cap
rotor arm
clean the ISV
check vacuum hoses
Then look at other stuff.
Old 02-01-09, 09:24 AM   #3
90 quid
pm me next time you go "shopping"
Old 02-01-09, 10:57 AM   #4
moomin
Cheap stuff 1st:
plugs
leads
dizzy cap
rotor arm
clean the ISV
check vacuum hoses
All of the above where done when I got is where could a get another ISV, audi want £135 and GSF with max discount £127
Old 02-01-09, 12:33 PM   #5
ebay?
I got mine for about £35 brand new.
Type in Audi ISV or Audi idle, or try part of your part number.
Clean it first though.
Steve
Old 02-01-09, 03:10 PM   #6
moomin
right solved half the problem air hose had come loose causing the misfire under power.
Still randomly turns off though, fuel pump relay maybe?
Old 02-01-09, 07:18 PM   #7
peanut
i was just going to say it sounds like an air leak. Id still check all of the other breathers etc and look for any splits etc. Take the ISV off overnight and soak it in petrol. Its not a permanent fix but if its just clogged up then it might cure it
Gav
Audi Q-Sport SWB poopcoupe Cars For Sale 5 25-01-09 12:06 PM
audi 100 sport i Micky Cars For Sale 7 23-12-08 05:15 PM
Audi 80 Sport Tarka Cars For Sale 0 03-12-08 02:22 PM
