Classic Audi » Technical » Mech/Tech » Suspension & Brakes » B4 Coupe Caliper Upgrade
Old 26-07-12, 07:57 AM   #1
boabskiboab
Default B4 Coupe Caliper Upgrade
Guys,
I'm considering upgrading my coupe single pot G60's to twin pot G60's.
Has anyone else done this?
Would i need to change the carriers?
Any info would be appreciated.
Cheers
Boab
boabskiboab is offline   Reply With Quote
Old 26-07-12, 08:15 AM   #2
Greavesy
hi mate,
i have just done this on my saloon.
You need the s2 carriers, but they bolt straight upto the hub.
I took the calipers I recieved apart, cleaned them all up, replaced the seals and painted them. I fitted EBC Yellow stuff pads, as I plan on doing the odd track day later this year. While changing the fronts, I took the rears apart, changed the seals, cleaned and painted them, I fitted new discs and and standard pads at the back along with new brake fluid. If you take your rear calipers off mark up which side is which! I had a mare with mine.
There are some pictures on my thread: http://www.classic-audi.co.uk/forum/...ad.php?t=22975
DONT use Goodridge hoses on the front, they're not long enough! I had some make up by a company in Rotherham, they were about £50 and are a good 4 inch longer than the Goodridge shyte.
Andy
Greavesy is offline   Reply With Quote
