Classic Audi » Technical » Mech/Tech » Engine » Dump Valve for t44
Old 26-10-08, 07:59 PM   #1
Scarlet
Scarlet's Avatar
Default Dump Valve for t44
I want a dump valve for the Type 44, its the MC engine 10 valve. (2.2 turbo quattro)
I want one that makes the noise you get off the newer ones (the woosh of air sound lol) can anyone give me a link or contact details of anywhere i can get one?
t44 2.2 turbo quattro
B4 80 Avant
t44 100 2.0 saloon
Quattro Nation
Scarlet is offline   Reply With Quote
Old 26-10-08, 08:09 PM   #2
be very careful when fitting a dump valve. can cause more problems then they are worth.not sure about audis but some systems are sealed breathing .and dump valves cause erratic idling.get advice before you do it.
Old 26-10-08, 08:31 PM   #3
Scarlet
Scarlet's Avatar
The car already has a dump valve as standard fitted to it
B4 80 Avant
t44 100 2.0 saloon
Quattro Nation
Old 26-10-08, 08:38 PM   #4
not sure ,are you on about the wast gate?
Old 26-10-08, 08:41 PM   #5
Scarlet
Scarlet's Avatar
No the waste gate is fine, however i was told the dump valve would need replacing soon.
Seemingly these were bad for going on this engine or something, but the guy hasnt ever fitted an after market dump valve to this engine so couldnt advise on which ones to buy.
Im going to be fitting the uprated waste gate spring but the car is down on power becasue of the dump valve so want that sorted first
B4 80 Avant
t44 100 2.0 saloon
Quattro Nation
Old 26-10-08, 08:49 PM   #6
He's confusing dump valve with blow-off valve
Dump is better, without that stupid "psh-psh" sound all thime Ok, some kids like them - "I'm the real need for speed man"
P.S. I heared that big pressure difference can reduce life of turbo - in case of blow-off.
Old 26-10-08, 08:50 PM   #7
i must admit i have never seen a dump valve on a older audi . what does the book say if you have one?
Old 26-10-08, 09:37 PM   #8
rado-steve
rado-steve's Avatar
No A dump valve makes the the K-shhhh noises associated with Turbos, it is a device to dump excess boost to stop the turbo stalling when you come off the gas and back on it again!
I think most VAG turbo applications from the factory run a re-circ system nwhich dumps the excess boost back into the system!
rado-steve is offline   Reply With Quote
Old 26-10-08, 09:42 PM   #9
rado-steve
rado-steve's Avatar
If it dunt make the k-shh sounds already it prob has a re-circ system! Best off talking to Forge about their uprated re-circ valves!
Summat like this:
http://www.forgemotorsport.co.uk/con...oduct=FMCL007P
Not sure if that particular one will work on your engine though, they also sell uprated waste gate actuators!!!
Old 26-10-08, 09:44 PM   #10
Dump valve connects exhaust side of turbo to intake side of turbo, while blow-off connects exhaust side with atmosphere, making this sound
B3 80 Sport SE 8 Valve David Small Cars For Sale 0 04-09-09 12:13 PM
looking for 1 exhaust valve sam Engine 2 15-05-09 07:33 AM
Dropping a valve @ 20k!? Gaz Engine 5 10-01-09 11:05 PM
How not to do a valve job joe90 General Chat 4 03-12-08 06:25 PM
