Members: 19,816 | Total Threads: 40,093 | Total Posts: 471,108 Currently Active Users: 12711 (1 members and 12710 guests) Welcome to our newest member, Nickvah |
I've just bought a h reg 20v 90 it needs a couple of bits done before i can drive it though, so i have a couple of questions someone on here might be able to answer
firstly the previous owner broke the only key in the ignition (how i have no idea) will all the locks from a 80 coupe fit a 90 saloon (i'm bidding on a set on ebay). The rear brakes are needing work it definitley needs disks and pads but i think it might need calipers as well as the handbrake binds on, do calipers from any newer VAG car fit maybe from a A4 as i know all to well about the handbrake calipers on early 90s audis and vws and if i need to replace them i might as well fit better ones. |
Hi there indrid, you could always try a locksmith to remove the broken key and they should be able to cut you a new key, i had a mates uncle do one for me a few years ago.
Bryan |
You should be able to get a new barrel for the car and then get a locksmith to re configer the door lock barrel to match
![]() Horsepower is the force that determines at what speed you hit the wall, Torque is the force that determines how far you take the wall with you after you hit it. |
I did have a barrel a key kicking about but it is a while since i have seen it, i will have a look around through the week and see if i can find it.
Bryan |
saloon and coupe do not have the same locks strange as it may seem pop over to audifans .net there is a thread about it.
Steering lock could be but the door locks def. are not
Thanks, I'll have a look once they arrive, might just be a case of putting them back on ebay though
. unless i can use the internals of the coupe ones in the original barrels (i've rebuilt locks like that before on a vw but it was using parts from the same model) though they are probably different.I saw the thread on audifans.net, you would have though the barrels would be the same on the saloon and coupe though. |
Many years ago I had to replace the ignition barrel/steering lock on a car that had been stolen. I got one from a main dealer (based on the chassis number) and it came with a set of keys that also matched the door and boot lock. Silly question - hav you tried a main dealer?
Audi 200 5E Subaru Forester XT On-One Inbred 456 |
| Rear brakes Audi 80 | Bowma | Suspension & Brakes | 4 | 29-01-10 11:03 PM |
| UFO brakes on Audi V8? | NBirkitt | Suspension & Brakes | 0 | 25-05-09 05:01 PM |
| Audi Coupe Quattro Brakes and Fleix Pipes | Martc | Suspension & Brakes | 23 | 20-04-09 09:56 PM |
| Wanted New brake discs for a '71 Audi 100LS (inboard brakes) | mattp | Parts Wanted | 6 | 07-08-08 01:03 PM |
| Audi 100 brakes problem | pimpdriver | Suspension & Brakes | 3 | 01-02-08 10:16 PM |
