Classic Audi » Technical » Technical Info » Advice on Head gasket needed !!!
Old 22-09-11, 03:54 PM   #1
tttoptotty
tttoptotty's Avatar
Unhappy Advice on Head gasket needed !!!
Slimer is using a lotsof coolant but no liquid on the ground oil is fine not turned into mayo it's nice and clean coolant tank has no oil or any other substance in it just the usual coolant etc but any ideas as to why my coolant lights keeps coming on and it always empty cant see any split pipes of loose clips or any such like Ive checked the most obvious things but does anyone know if there is some weird and wonderful thing that could be imitating the symptons of a head gasket on it's why out thanks guys
Audi the ride of your life
Old 22-09-11, 04:04 PM   #2
Hanuman
Hanuman's Avatar
Heater matrix? Carpets damp?
Old 22-09-11, 04:28 PM   #3
stuartmmcfc
there might not be anything on the floor and no signs of split hoses but have another careful look, especially on cold mornings when steam might be more obvious and on the underside of the hood for any stains etc.
Old 22-09-11, 05:17 PM   #4
Phil Payne
Actually, you need your friendly mobile Audi expert to pop round with a coolant pressure tester:
http://www.isham-research.co.uk/quat...ges/19-170.bmp
You won't find small leaks on a hot engine - the coolant evaporates at source.
Old 23-09-11, 05:43 AM   #5
tttoptotty
tttoptotty's Avatar
Ive got no damp carpets, no steam and no white smoke so only the usual suspect to be honest boo hoo
Old 23-09-11, 06:50 AM   #6
As already mentioned a small leak when engine hot may be hard to find, don't think the worst, keep an eye on coolant level, allowing to develope might be an idea depending on how good you are at remembering to check/top up coolant.
Old 22-09-11, 04:23 PM   #7
Phil Payne
Coolant can 'burn' and exit through the exhaust pipe. If the antifreeze mix is correct, burnt coolant will smell acrid and 'sharp'. When it gets bad, you'll see white smoke.
