Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,156 Currently Active Users: 14190 (0 members and 14190 guests) Welcome to our newest member, BuddyInons |
Wonder if anyone could point me in the right direction for this one?
The last 2 days my 80 has a fuel smell inside when driving (cabin vents), seems to be more intense when cold or racing the engine... I have had a butchers under the bonnet to no avail No obvious leaks, but have noticed a slight back fire (pop pop) when gearing down from the exhaust.Suggestions to the cause/fix would be greatly appreciated. Chrisp.
B3 80, Kamei. Toyota MasterAce. Mazda 5. |
“Been raced and rallied”
Could be your exhaust is blowing / holed.
as above
sucking in air through a joint or hole in the exhaust (or manifold) and pushing fumes out under load |
Thanks, will dust the ramps off and have a look tomorrow.
May be well wrong but check the fuel lines too .....
on top of the above, i've had fuel the tank/sender sealing ring letting out a whiff! but that was a volvo.
