Classic Audi » Classifieds section » Parts Wanted » T81/T85 engine mount
Old 30-07-11, 12:20 PM   #1
Default T81/T85 engine mount
Needed ASAP please!
Old 30-07-11, 01:32 PM   #2
Phil Payne
Needed ASAP please!
Haven't got one - sorry.
But be aware that there is a BUG in the ETKA database that has cost a few people an exhaust manifold.
The right engine mount for the ur-quattro used to be higher/larger than the left. Audi consolidated these parts and now only ships what used to be the left mount for both left and right, with an additional 6mm spacer for the right to make up the reduced height.
However - ETKA has it wrong. On page AQS/1985/1/99/21-00 the items 19 and 20 for the right mount come up 'part number unknown'. There is a spacer shown on the left mount as '19A' - if you look at the text there is a another line (19A) with the text saying '52x6 right'.
A lot of parts monkeys miss this and will thus supply you with the mount but not the spacer. This leads to the engine sitting too low and fouling the subframe - it also makes idle adjustment difficult because you can't get the screwdriver in to the adjustment screw in a straight line.
Old 30-07-11, 08:47 PM   #3
type81
type81's Avatar
Which one do you need? The one with the 6mm spacer or without?
GIMETAL GERMANY GRUN 823 199 381 C AUDI 823 199 381 R
(They both have same codes on)
Old 30-07-11, 09:04 PM   #4
4 or 5 cylinder ?
1991 90 quattro
Old 30-07-11, 10:06 PM   #5
jogi730
jogi
jogi730's Avatar
|Thought of getting some uprated ones from Bambridge?
jogi730 is offline   Reply With Quote
Old 30-07-11, 10:12 PM   #6
Originally Posted by mikes2 View Post
4 or 5 cylinder ?
Tis 5 pot. Will be a 7a.
Old 01-08-11, 09:36 AM   #7
Are you sorted or do you still need one.
Got one if needed. send me a PM
1991 90 quattro
