Classic Audi » Technical » Mech/Tech » Engine » Audi 100 QT - MC2
Old 27-10-10, 05:41 PM   #1
Quattro Power
Quattro Power's Avatar
Default Audi 100 QT - MC2
Hi guys,
I've been having problems with my 100 Quattro Turbo eating fan-belts.
I thought ok its either the alternator or battery thats knackered so I changed the alternator and the battery, then I realised that the tensioner bracket and bolt with the teeth were so worn that they weren't getting the tension on the belt.
So I ordered a new tensioner bracket and bolt installed them and the belt was tight............no problems for three weeks, then snap, no squeels or nothing just snap, so I put on another belt and it's started squeeling today after two weeks........
The pulleys are running straight and true, the only thing I can think is that the aftermarket belts I'm putting on aren't agreeing........?
I've had a mixture of aftermarket belts all 800 x 25.
Any ideas or anyone had the same problem?
Cheers,
Leigh
Quattro Power is offline   Reply With Quote
Old 27-10-10, 06:02 PM   #2
Phil Payne
Check the alternator pivot bolts.
Old 27-10-10, 06:38 PM   #3
Quattro Power
Good point there, will do!
Just realised a mistake the belts I've been using are actually 825 x 9.5..........that's what happens when you use the laptop while watching tv!
Cheers!
