Classic Audi » Technical » Mech/Tech » Engine » Injector Cooling Fan stuck on :-(
Old 01-07-10, 06:14 PM   #1
SteveCat
SteveCat's Avatar
Default Injector Cooling Fan stuck on :-(
Hi
The injector cooling fan is permanently on.The engines a 2144 KG unit on an 84 200 Turbo.
The only thing I can do at the moment is unplug it.
What have others here done to fix this problem??
I've had the rocker cover off today,involving removing things etc but Im sure alls back as it was.
I mean,I know its hot at the moment,but not that bloody hot!!
Mercedes E220 Sportline Coupe
Old 01-07-10, 06:16 PM   #2
Plug it back in , see if it carries on. Mine did it once and was running for hours, I disconnected it then reconnected it and itsbeen fine since, tripping in as usual
Old 01-07-10, 06:19 PM   #3
SteveCat
SteveCat's Avatar
Default .
Already tried this mate,it doesnt.
Where should I check for the earth for this item??
I see a mucky brown cord nearby,and I dont mean summit Coxy just dropped on the back bench of a Maser!
Old 01-07-10, 06:24 PM   #4
Sorry steve just a thought!
Old 01-07-10, 06:26 PM   #5
SteveCat
SteveCat's Avatar
Default .
Sorry if I sounded a bit terse there matey.
No needus to apologise.
Old 01-07-10, 06:38 PM   #6
No, don't be daft you big soft lump ! Xx
Old 01-07-10, 06:47 PM   #7
if its the motor like a wr theres a heat sheild over the wast gate with a small thermo sencer on it with a brown wire to it thats the thing that turns it on if the wire is of and touching earth it will run all the time or if sensor fails .
Old 01-07-10, 06:48 PM   #8
In all fairness Steve, you'll be hard pressed to tell it's disconnected. I'd suggest you just do what you probably already do, and that's not to Caine it on the last couple of miles and let the old girl idle for a couple of minutes before shutdown. This'll help take some of the heat out of the exhaust manifold and reduce fuel vapourisation. And check the sensor, ISTR it's up by the wastegate.
edit.... Blast.... Briggers has beaten me....
Old 01-07-10, 06:59 PM   #9
ha harrrr beat you to it lol
Old 01-07-10, 07:37 PM   #10
SteveCat
SteveCat's Avatar
Default .
Ah! Briggus went into 0800-Brigassist mode and rang me while I was up the woods with Hobley.
I was trying to sound grateful while my lighter had decided to pack up.
Cheers John,got back to the car once he'd done a poo and disconnected the bloody thing.
All my pipes are connected sturdily with regards to being a bit down on performance.
I may have to pay a Gas ANALyzer friend a visit.
What is the c.o setting for a KG?
Its idling really well.I set the idle this afternoon and just needed mild tweakage.
I ragged it on the way back ,using 2nd gear holdus on the old Box of Slush and she is rather urgent.I think its the humidity which is making her feel a little slower today.Oh,and the fact that the fuel pump is on the way ooot!
