Classic Audi » Technical » Technical Info » GT Coupe problems
Old 25-09-08, 07:15 AM   #1
poopcoupe
21 + 19 = OLD!
poopcoupe's Avatar
Default GT Coupe problems
2.0 JS gt coupe 85.
When I start the car up when cold or if its been running, she only fires up on 4 cyl then 2/3 seconds later cyl 5 kicks in. Any ideas?
Old 25-09-08, 07:22 AM   #2
MikeNZ
Dribbly Injectors?
MikeNZ is offline   Reply With Quote
Old 25-09-08, 07:23 AM   #3
Check nozzles
Old 25-09-08, 11:21 AM   #4
20vcqdriver
20vcqdriver's Avatar
Thumbs up injectors
Ditto those comments, you have a poor sealing injector. If high mileage it would be worth changing all 5 whilst you are at it plus the seals.
Old 25-09-08, 11:50 AM   #5
Replace, replace and again replace It's so cheap, isn't it?
Most of all "cleaning" additives are crap, and real cleaning is what does the job. In case of nozzles - nozzles can be cleaned with ultrasound
And, after all - simpliest way how to check is by removing all nozzles, lifting air meter flap upvards, and then ask someone to crank the engine, while targeting nozzles to safe point In action there is big difference between bad and good ones
Of course, if u have so much money, install brend new set Btw, how does cost one brend new Bosch nozzle?
Old 25-09-08, 03:30 PM   #6
TheTwelveQuidKid
TheTwelveQuidKid's Avatar
An old diesel mechanic friend told me you can clean them by lightly tapping them with a very small hammer while the engine is running. I had limited success with this on a BMW once.
Old 25-09-08, 11:00 PM   #7
20vcqdriver
Cost of new injectors from GSF not expensive for these engines compared to my 20Vt at £35ea, and if this is confirmed as the issue then bite the bullet. Better than wasting time and money trying to keep the 20 year old ones going a bit longer unless you are trying to get it sorted to sell it...
hot starting problems Darron Edwards Engine 41 15-04-10 10:30 PM
Hot Starting Problems stumack7 Engine 19 26-03-10 06:28 PM
Help!! - Starting problems Couperman Electrical problems 8 09-01-10 10:14 PM
CQ Problems Alski501 Engine 3 16-12-09 07:41 PM
Running Problems Baggee Engine 3 10-08-09 10:02 AM
