Members: 19,809 | Total Threads: 40,093 | Total Posts: 471,107 Currently Active Users: 4392 (1 members and 4391 guests) Welcome to our newest member, gldxosdyh |
hello,........
![]() radiator fan .....on......all the time.....??? as soon as i connect the battery....? disconnected the temp sensor on the rad...............ON..... has anyone had this...?? wondered if it an 'open' or 'closed' circuit problem..? thanks |
if you taken off the plug than it shouldn"t work
somewhere the wires are touching each other ? |
Nien
This has happened to me before. It was my Multi function sensor. Its on the coolant flange coming off the motor. It also ended up almost setting the relay on fire so be careful.
#6 | |
thought that it was the culprit in a number of other issues..........so, i will take it out and carefully............smash it to bits...! |
Vorsprung durch Technik!
This might be nonsense but couldn't it be the fan switch in the rad?
Cheers Nathan
#8 | |
![]() on an audi 100..... does the switch close to turn the fan on...? or does the switch open to turn the fan on...? because i disconnected it, and the fan was still running.............. |
Missfire, does the fan relay click when you connect the battery?
Does it still run if the relay is removed? If no to both then most likely the relay contacts welded together. If the relay does click then something is triggering it, MFTS, Fan after run relay, radiator switch, wiring short, etc............. If it does still run with the relay removed then the motor feed is shorted to B+. If the fan has more than one speed, then each speed will probably have a separate relay, Which speed is the fan running at when it shouldn't be? I'm quite sure that most fan switches will be normally open (ie closed = fan on) |
Woodsman
i will check out the relay...pretty sure it is a single speed system but will make sure..! it does not seem to be running very fast.....so if it is a 2 or 3 speed system, it is running on the 'lowest speed' setting,....all the time...! weirdest thing was....i was out and fitted a new heater resistor pack into the blower motor housing.......no drama...(blower still does not work !! blower motor works with a direct feed, so the controls must be nackered... ..) then went indoors for about an hour..then let the dog out for a sniff around .........and the fan was running ... ![]() and now it wont go off... so watever happened...it did so without the ignition switch on.... ![]() anyway...i will go for a snoop one day with a multi-meter....thanks |
| type 85 radiator | john johnson | Parts For Sale | 0 | 30-08-09 07:22 AM |
| kv radiator | slacky | Parts Wanted | 4 | 31-07-09 08:35 PM |
| 10v Radiator question | djb1607 | Engine | 7 | 31-07-09 05:31 PM |
| Radiator, will this one fit? | Scarlet | Engine | 2 | 07-05-09 06:25 PM |
| New Radiator | poopcoupe | Parts Wanted | 28 | 16-01-09 05:28 PM |
