Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,149 Currently Active Users: 9290 (0 members and 9290 guests) Welcome to our newest member, BuddyInons |
Mr Typ 43!
What is my best course of action for sorting out my cracked manifold (off a 1982 200 5T, engine code WJ)? Repair, replace?
Manifold.jpg Manifold1.jpg Manifold2.jpg |
either try and find someone willing to weld it or go tubular!!!
90 Quattro Project http://www.classic-audi.co.uk/forum/...read.php?t=235 Passat 130 Sport http://www.classic-audi.co.uk/forum/...5830#post15830SOLD http://www.helpforheroes.org.uk/ www.armedforcesrallyteam.com |
i had mine welded 18 months ago and its still ok all you need to do is find someone who knows what thay are doing
john...
Mr Typ 43!
Anyone know of anyone in the Oxfordshire area who knows what they wre doing with a welder?
any decent welder should be able , i did it , v grooved the cracks slightly, buzzed it ap /ground back and same again, it was no problem, BUT I DID REPLACE THE ENGINE MOUNT ON THAT SIDE just to be sure that the manifold took less strain
hi there chris hows the RS2 going you old sausage all the best and a happy new year
john... your q.o.c. area rep
is that you dad? RS2 is good , some new paint , new stat, the beast lives....., 200q has a treser double intercooler , new belts, etc[winter overhaul], saab 900t soon new ic /leather carlsson gauges, .....what else? coupe q will be done this decade starting the body....may go for the kermit green body with satin bonnet/boot....scala43.de if you are bored...nb i am looking aftermy neighbours honda 400 four p plate, classy, will i see you at cosford?
Mr Typ 43!
Gave the manifold to a guy at a local fabrication / welding workshop - he seemed to think he could weld it - and for £20/30!!
Mr Typ 43!
There is about a 5mm gap between the sump and crossmember - should it be more? Where can new mounts be purchased?
5mm sounds a bit tight, try vag parts, your local dealer, or south hereford audi , but quattro corner is likely your best bet
i would think that the ur quattro mount is the same,i certainly used one on my 2005t no probs, , the mounts get tired over the years, coupled with the heat on ths exhaust side of the engine, if you replace it buy or fabricate a heat shield to help with the heat soak. regards chris |
| Need Exhaust From Manifold | tommyboy | Engine | 4 | 19-07-09 10:32 PM |
| Exhaust Manifold | andy e | Engine | 0 | 29-03-09 01:03 AM |
| Dialynx exhaust manifold. | 4v6 | General Chat | 12 | 02-03-09 09:57 PM |
| exhaust manifold VW 2.4d I-5 non-turbo | knobstar | Parts For Sale | 0 | 10-09-08 04:35 PM |
| Ur exhaust manifold | 4v6 | Parts Wanted | 15 | 07-02-08 06:04 PM |
