Alternator for early diesel 100/80's
4 Attachment(s)
Right! (Deep breath)
Here is a new/unused Bosch alternator p/n 0 120 489 369 which basically cross references to the Audi exchange p/n of 068 903 017NX. It is a 65A version. It was purchased for an Audi 100 TD but it looks like it will fit most 80's circa 86-92 with the 1.6D/TD engine, that is the indirect injection not the TDi! It will also fit the Passat with the same engine 86-88 and even the LT 2.4D 90-96! The pulley and fan were for the 100 version. There may be differences for other models. Please use the pictures to compare with the intended replacement. There are other p/n's that cross reference. If you forward approximate year of vehicle I will try to check applicability. Alternatively see here: http://www.woodauto.com/Unit.aspx?Ma...Ref=0120489369 £60 delivered within UK. |
| All times are GMT. The time now is 12:26 AM. |
