Alarm Problem 94 Coupe
Hi Guy's,
I have discovered a slight problem with the alarm on my coupe. When you lock the doors it usually gives off a little bleep to say the alarm is on (i assume) but when i opened it the next day the bleeping started from the minute i unlocked the car and only stopped when i opened the door! I know the siren is under the O/S/R wheel arch. Can i disconnect this or will it cause further problems??? It seems to be intermittent at the moment any common things that would cause this ?? Cheers |
| All times are GMT. The time now is 06:17 AM. |
