-   -   dizzy cap leads order (http://www.classic-audi.co.uk/forum/showthread.php?t=5591)
tommyboy 08-07-09 03:11 PM
anyone know witch order the leads should go on the dizzy cap...as on ma previous car they were all missing....i have the leads....jst need help:)
cheerz
Audi Derek 08-07-09 03:23 PM
4 or 5 pot.....
Audi Derek 08-07-09 03:34 PM
This should help..
Firing order for a 4 cylinder is 1-3-4-2.
Firing order for a 5 cylinder is 1-2-4-5-3.
Check that the rotor arm points to the mark for No 1 cylinder on the rim of the dizzy housing it is a shallow groove then working clock wise you should be able to work it out..
tommyboy 08-07-09 05:57 PM
aye ill give that a try
the starter motor turns over ..and the engine turns over slowly without firing..theres fuel in the tank..cleaned the spark plugs....
might be a fuel problem?
ideas
its a 5 cyliner js engine 2.0
cheerz:)
