-   -   Fan BL@@dy tastic :( (http://www.classic-audi.co.uk/forum/showthread.php?t=5542)
Gaz 04-07-09 08:13 PM
I was at the lights in town today when I noticed the water temp was very high, infact almost on the H, I thought to my self, oh, something's not right? :shocked: I better pull over. before i could do anything steam started pouring out of the engine bay. :yikes: And only THEN did the red light on the dash board start flashing at me. :wall:
I pulled the car over, switched of engine off, popped the bonnet to see water EVERYWHERE. :eek:
basically due to some heath Robinson wireing to the fan, one of the wires had come off and so she boiled over. :(
I reconnected the wire, turned the interior heater fan on in the car full blast, and went to get some water. let it cool down for a bit, & re filled the rad.
started her up again and watched on tick over as the temp climbed higher and higher. :shocked: So it seems the fan isn't coming on any more. :grr:
I don't know if its the fan that is goosed, or a sensor or another electrical fault.
I'm hoping the engine is OK, but what i want/need to do now is hot wire the fan so its on all the time, or maybe put a switch on it.
What two wires do i need to cross to turn the fan on? :rolleyes:
I'm not happy.
4v6 04-07-09 08:32 PM
Just short the two on the rad fan switch and itll run all the time Gaz.
Gaz 04-07-09 08:35 PM
excuse my ignorance, but where is the switch?
Micky 04-07-09 08:37 PM
its now an air lock the rad has to be hot at the bottom where the switch is to work :tup:
just re blead the system with the heator controll on hot in the car so the water cerculates fully .this should cure the problem ;)
Gaz 04-07-09 09:05 PM
thanks guys.. i did wonder if it had something to do with the water level, because when i checked it the second time the water had gone down.. and after topping up i could 'feel' it in the hoses.
I didn't hear the fan kick in since, but its temps not got above half way since its happened, so i just wanted to make sure.
cheers.
this car seems to have had a few 'little' things go wrong that amount to potentially serious damage. :(
