-   -   Servicing items (http://www.classic-audi.co.uk/forum/showthread.php?t=5292)
Emjay 15-06-09 02:45 PM
Servicing items
Will be servicing the car shortly as part of the top end rebuild. Need some reccomends for plugs, oil, HT leads etc for a WN engine. Parts and distributors reccomends welcome.
Also need a new cambelt
thanks in advance
Martyn
PeterB 15-06-09 03:52 PM
thanks in advance
Martyn
Pete Reeve at quattroCorner should be able to sort you out with most of those Martyn.
For the HT leads I'd see if Magnecor make a set for your engine, the 7mm black ones that they do are fine and will look pretty o.e.
As for the oil, a good 10W-40 or 15w-40 should be spot on. Something like the semi-synthetic Synta Silver 10w-40 from VW.
:tup:
gabriel.oconnell 15-06-09 05:57 PM
yes go to peter reeves of quattro corner for all you audi needs what a great guy
amanda 15-06-09 06:24 PM
Yes either pete reeves or if you are really feeling brave take her to your local dealer and order the parts from there :)
