Arrgh.....Heater Valve for WR!
Hi, need to replace the HEATER VALVE quite urgently on my WR. Does anyone have one spare that they'd be willing to sell?
Kind regards Stu |
would this be the same thing as the warm up regulator valve?
if so got a new one here |
Hi mate, its in at a garage at the mo as I had a coolant leak from a pipe that goes into the bulkhead, under the power steering fluid resi. Been told that the heater valve needs replacing? Its all i've been told, sorry. Does this mean anything to you Rich?
have you spoke to Pete Reeve at quattro corner yet? Dont know if wrs are different, but got one for my mb from him very recently.
£19. |
touch base with Badal, he is breaking an MB not sure if its the same set up though.
or phone Will on 07784549952 or 01604 812399 he has broken up a few quattros so perhaps able to assist you.:idea::tup: www.enquiries@vaudirectrecyclingsolutions.co.uk |
IIrc its the same item as fitted to mk1 golfs too.
its not Rich, it may be the three pronged black plastic thing that the pipes go into with a little lever on top, tends to stick as well
JJ |
Many thanks guys, will try Pete Reeve tomorrow, if not i'll try those numbers Rich.
Kind regards |
think i ve one froma gt, they all look same
if its the bit me and JJ think it is get a new one - they all seem to leak with age aeventually
| All times are GMT. The time now is 11:44 PM. |
