-   -   WANTED clocks for 90 20v Sport (http://www.classic-audi.co.uk/forum/showthread.php?t=4932)
ian20v 17-05-09 05:34 PM
1 Attachment(s)
After further investigation turns out or looks like clocks or connection is faulty so lookin for said item, has to be from 20v as i've been told plug ins at rear are different.URGENT! CHEERS!:tup:
msh 17-05-09 06:00 PM
Only thing that is different between B3 speedos is if it does have or doesn't have trip computer and/or auto check, and, also, tachometers [2v engines have 6,2k redline, 4v 7k redline, and also R4 and R5 speedos differs electronically] and speedometers [A80 have 220 kmph, A90 260 kmph], but speedometers and tachometers are interchangeable, so u basically need B3 speedo with trip computer [and auto check, if u have it].
P.S. What's wrong with your speedo?
ian20v 17-05-09 06:18 PM
Thanks ! it failed mot as not displaying any abs,battery light or autocheck,I had it working intermittently today then packed up.I've got a replacement from
Botsdad on this forum.
msh 17-05-09 07:19 PM
Omg :yikes: In latvia @ technical inspection works idiots where pass/don't pass depends on inspector's mood, but looks like MOT in UK is just amazing :lol: Here in case if ABS isn't working and owner don't want to fix, he would remove bulb and pass with no problems :D
Anyway, looks like your speedo just have cracked electrical paths and it's easily repairable with soldering iron :)
Booty 17-05-09 07:32 PM
Got a set Ian from my Old 20v quattro sport. It has the computer but the screen has 'bled'. Everything else works on it. PM me if interested.
