Rubber door trim/strip
Hi all,
Another piece im after, I want a replacement rubber door strip for my 1985 Audi 80 - you all know the one by now! Its the rubber trim that runs the length of the door, and its for the passenger side rear. Many thanks in advance, Sie!:tup: |
Hi Sie, I've got one of those, but not sure on the condition; will have to check at the weekend, but if someone else offers one, go for it, in case my spare is not perfect. Cheers.
Hi Geln!
Thanks once again for that, appreciated as always! Micky, again, thanks for that tip, but the ones on mine are slightly different. Sie!:tup: |
1 Attachment(s)
Cheers. G |
Hello Mr G!
Hows things? Its not actually that piece im looking for - just read my ititial post and it is a little vague, so my apologies for that. The actual piece im looking for is this one here:- http://www.simonbaskerville.pwp.blue...rimneeded!.jpg As ever mate, thanks for your help! Sie!:tup: |
Hi Sie!
Ah; the dreaded outside trim. early ones were much more resiliant, these later ones rusted from the inside out. Removing them is difficult, best as a cheese-wire job, so most get bent & as soon as that happens they're useless. Anyway, all of that you probably know & it doesn't help much because I've not got one detached :sad:, but I have just remembered I've got a set of doors that have got that type on. I'll have a look and post a pic in a few days to see if it is any good? :). Cheers. G |
Hello Sie, Well I found one. It's reasonable, but is plain black, but I think yours may have the 'chrome' insert in the top part? I've not bothered to photo yet as if that's the case this one aint no good. Also where the bottom of the two metal strips runs through it, if you look very carefully, you can see it's starting to bubble slightly under the plastic; so may be no better than yours. Cheers. G.
don't shout at me but ive just removed all of my rubbing strips and thrown them away.....if id of known you could of had all of them
Hi guys,
Sorry to threadjack, but I'm looking for the same piece for the driver's (front) door. :) |
| All times are GMT. The time now is 07:23 PM. |
