part number for fuel pump relay
for my 100 c.s its got a mickey mouse one in there causing my non start (well i thinkits the fuel pump relay !!?) as its not labelled and its not in the manual!!
but it does look like an after market one reg is e690ybw hope u can help thanks |
part number is 443907385F , relay location 10 on the fuse board under the bonnet, make sure the fuse box lid is tight on, or water from the windscreen runs onto the fuse board and causes all sorts of problems.
retail price from Audi is £61.99 including vat, and they have 3 in stock at Audi, but you may find a second hand one as they were fitted to the likes of golf gti's just check the numbers on top. not sure if you can get non genuine, but may be worth a try. eltee |
o.k thanks very much for your help mate
| All times are GMT. The time now is 10:52 AM. |
