-   -   B2 80/90/coupe front wing (http://www.classic-audi.co.uk/forum/showthread.php?t=38976)
jimh 20-07-19 04:09 PM
Wanted drivers side (RHD) front wing for B2 80/90/coupe.
Any condition, the worse the better for most of the wing.
The only part I need to be in good condition is the top section that bolts down onto the inner wing (basically all of the part of the front wing which is under the bonnet.
The rest of the wing could be cut off to save on postage as I don;t need it.
I have rust on the top inner wing of my '85 Urq which has spread to the bolt-down top of the outer wing. I intend to cut that section out of my Urq wing and weld in a good section from an otherwise poor wing.
Isimmo 22-07-19 09:34 AM
Hi Jim
I saw this and thought of you.
https://www.ebay.co.uk/itm/Audi-Coup...IAAOSw7CBdIhb1
a1quattro 24-07-19 08:40 PM
be carefull not too warp the ur wing welst welding the replacement wing rail . take your time and damp down each weld ect
