Heater blower problems
Hi does anyone know where I can get a wiring diagram for the heater blower system for a b3 80, as my blower fan is only working on speed 1&2 and nothing at all on 3&4 if anyone has any idea what's wrong that would I would be grateful cheers
This is for the AC but the fan wiring should be mostly the same:http://www.getwiringdiagram.com/wiri...udi-80-png.png
If the fans working on a couple of speeds but not the others thats usually a sign of a blown heater motor rheostat, shouldnt be huge money and a second hand unit will more than likely fix it,
4v6 are you on about the resistor on top of the blower motor housing
I had same problem on my 90, resistor on blower motor was the culprit. Hides behind the glove box. Find and press locking tab and twist/turn the motor and lift it out to get access
This is the part from memory. http://www.ebay.co.uk/itm/NEW-Audi-8...wAAOSws65TrFVk |
| All times are GMT. The time now is 05:28 AM. |
