Ur Quattro Accelerator Pedal linkage bush
Im after the bush that captures the accelerator cable under the passenger side of the dash where it joins the lever mechanism. Any info/ ETCA diagrams etc appreciated. VBR Ian.
i've a couple, I can send to you, if i find them. friable bushes, also across the entire VAG range. i'll post some info shortly
Audi 100/Avant
Audi 80/90/Avant Audi 80/90/Avant quattro Audi Coupe Audi Coupe quattro Audi quattro/Sport Audi 4000 Audi 4000 quattro Audi 5000 Audi Fox Audi Coupe Audi quattro Volkswagen Caddy Volkswagen Golf Volkswagen Golf Cabriolet Volkswagen Jetta/syncro Volkswagen Passat/4Motion/Santana Volkswagen Passat syncro Volkswagen Scirocco Volkswagen Santana/Variant Volkswagen Santana 2000/3000 Volkswagen Rabbit Conv./Golf Cabrio. Volkswagen Dasher Volkswagen Fox 302,307,309 Volkswagen Jetta Volkswagen PickUp Volkswagen Quantum Volkswagen Quantum syncro Volkswagen Citi Golf Its actually this bit- 431721559. Item 6 and item 7 being the same part. So fit two new ones. http://uploads.tapatalk-cdn.com/2016...bc387dc4e1.jpg |
Same thing happened a year or so ago, try this.http://www.ebay.co.uk/itm/VW-T4-TRAN...item336c97dbb9
Thanks folk that's superb.
If you've got one Mark, yes please... it looks like item 7 for a RHD car. |
I'm not back in the uk/south for a few weeks. I'll see if I can get someone to dig them out.
You do need two. The cable hooks into one, mounted in the balance lump, IIRC, and the balance lump hooks into the second which is mounted in the transfer arm. They're reasonably cheap, though. Or they were. Looking at the thread on the other channel, JimH used the ones that Darreno'd linked to above. |
Yeah, use that Ebay one. It's much better than the original. The Ebay one is made out of some kind of rubber,the original one appears to be made out of some kind of soft foam which eventually crumbles to dust.
The ebay one was easy to fit with some mk1 spittle lube and pipe wrench type pliers, but only if you assemble in the correct order. I think the bush needs fitting into the lever before the cable is fitted to the bush which ISTR being counter intuitive at the time. The cable feels nice and secure in the Ebay bush and I haven't noticed any downside. |
Thanks folk,
I have had a chance for a closer inspection today and 'found' this, which I assume is item 5 resting behind the carpet... http://i245.photobucket.com/albums/g...pssy8kyllk.jpg http://i245.photobucket.com/albums/g...pslbosdio4.jpg As a temporary fix to get the car home I had just attached the cable straight to the lever and adjusted the cable accordingly, not realising there was a chunk of metal called 'item 5' missing. http://i245.photobucket.com/albums/g...pskhcbkcdc.jpg The question is, what does item 5 actually do? This is what the RallyRep looks like which is the CQ set-up... http://i245.photobucket.com/albums/g...psozm2x60z.jpg PS - Just ordered a couple off ebay... |
Get the Volkswagon equivalent as it does not disintegrate like Audi's.
For some reason VW use urethane bush rather than the rubber Audi one. |
The metal piece is just a weight probably to aid the return of the pedal to its home position. You need two of those bushes did mine today!!!
Sent from my SM-N910F using Tapatalk |
| All times are GMT. The time now is 12:47 PM. |
