Mechanic/bodyshop recommendations Luton area
The old girl has been off the road for a while (again) due to a front suspension spring being broken. Decided to have a play and reduce the spring rates all around and as all things with my car, this took much loner to sort out than imagined.
Work completed now and car sailed through MOT:). however, car got advisory for some play in rear wheel bearing and also noticed some rust creeping in on underside of car. need to get both sorted but my old garage is a bit far to travel. Can anyone recoomend someone good in the Luton area for both mechanical work and body work. prepared to travel a little but not too far. Thank you in advance |
VagTech in Bletchley for mechanical?
http://www.vagtech.co.uk/ used them for mechanical stuff on B5 A4 QTS. Happy with their work . I'm sure Neil Birkitt at Autometrix uses them on his Golf GTi mk4 iirc. |
| All times are GMT. The time now is 12:13 PM. |
