-   -   N/a 20v non starter (http://www.classic-audi.co.uk/forum/showthread.php?t=33108)
audicoupeparts 30-06-15 07:05 PM
N/a 20v non starter
1 Attachment(s)
Latest acquisition.
Turns over fine, won't start
Place I bought it from said it started then cut out
I'm thinking fuel pump
Changed relay for known good one
Does 10v pump straight swap?
I've a good one here I could try
Not had time check spark etc but will go through usual suspects!
mikes2 01-07-15 07:09 AM
pump should prime for a couple of seconds when the ignition is turned on.
If you cant hear that, then either the pump is faulty or the pump isn't getting 12v - fuse or relay normally
quattrodave 02-07-15 04:36 PM
Check the distributor just in case the gear has snapped thats what killed mine on one occassion, if not the 10v pump is direct fit for testing purpose.
audicoupeparts 04-07-15 12:52 PM
Swapped pump over and started straight away (well, after me forgetting plug pump into tank cover top!
Spent half hour dissecting VAG aftermarket alarm and checking dizzy first
Just needs a wash before I dare it to fail an MOT
