Fault codes
Can anyone i have a fault code P0030 h02s bank 1 do i need a new sensor or is it a eletrical fault:
this website (I just googled your question)
http://autogrom.com/honda/2008-12-21...-50-58/70-cods says: Code: P0030 Fault location: Heated oxygen sensor (H02S) 1, bank 1, heater control - circuit malfunction Probable cause: Wiring, H02S, ECM Which doesn't help, but it just means you have to do some poking round. Can you change the sensor, or swap it with someone who has one??? Cheers Steve |
cheers for info Steve i think the heater part of sensor at fault
| All times are GMT. The time now is 11:31 AM. |
