UR Q Fuel lines needed.
Hi guys,
I'm after a set of fuel lines for my 85 UR Quattro. Ideally I would love a set of new original ones but am having trouble tracking them down (hens teeth spring to mind). Does any one have a spare set i could buy or any idea of what to use for replacements? I didnt really want to go down the road of having to bend my own from scratch out of kunifer, but now I'm thinking that I will have to. Cheers |
I'm sure the fuel lines are NLA. I went down the kunifer bending route, it was tricky on axle stands, but do-able. Some members have used plastic lines too - see mrpat's 80q thread.
Hoyle |
Yep been NLA for the Ur Quattro for a couple of years now.
I got mine all redone, in metal, by the garage I used in Bournemouth. They just bought a few lengths of metal pipe (graded for fuel lines!) and worked it into shape. Worked a treat and all in all wasn't too expensive!
Mine cost about £35 for 25ft of 5/16 kunifer, then just used basic bending and flaring tools.
Had the old ones off and new ones on within a day. |
Remove the old fuel lines, take them as they are without bending them to a half decent garage/workshop and they will make new ones, probably out of kunifer, refit and forget.
The lines can be removed intact particularly given there's no battery tray to contend with, and even unbolting the steering rack and moving it out of the way slightly would help. A decent workshop can bend new pipes using the old ones as a pattern. It's not a nice job, but done right in the first place and it need never be done again. |
Lefthooker & Hoyle are quite right it is do-able, even on axle stands, as Lefthooker points out I did comment quite extensively on this topic in the last week or two. However, takes about 4/5 hours on the ramp depending on how co-operative the car is. Genuine replacements are NLA, but were priced at about £75 plus VAT each so even if you find someone other than me who still has some they are going to want about £200. Cranwell, Lincolnshire is only 68.1miles from The quattro Workshop so get it on a trailer. I'll stick it on the ramp and make it some new pipes in 5/16th cunifer. The overall cost won't be substantially any different and you wont have to buy a flaring kit that you may never use again, spend a day grovelling on the garage floor covered in fuel and as always you get my personal guarantee the job will be right!
There's an offer not to be turned down :tup:
| All times are GMT. The time now is 10:52 PM. |
