-   -   1986 100 Throttle cable LHD/RHD? (http://www.classic-audi.co.uk/forum/showthread.php?t=2735)
Lankytim 04-12-08 05:12 PM
The only thing keeping my 1986 100 avant off the road is a lack of a throttle cable!
Ive tried everywhere but nobody has a cable for a 4 cylinder carb model. The closest I can get is from the Audi main dealer who can supply a LHD cable from Germany, in theory it should be slightly longer than the RHD version and so would be usable but can anybody tell me for sure?
quattrokid 04-12-08 05:19 PM
have you tried quattro corner?;)
Pete Reeves may be able to help you
http://www.quattrocorner.com/
Lankytim 04-12-08 07:58 PM
Will do, thanks!
pimpdriver 04-12-08 08:28 PM
what about something off any 80 or 90???
Probably a similar fixing either end????
Lankytim 04-12-08 10:48 PM
The 80 is totally different, not tried a 90.
TheTwelveQuidKid 05-12-08 02:49 AM
Unless anyone can tell you for sure, it could be a case of trial and error (hopefully not too many errors).
If it was me, I'd probably go to a breakers yard (the good old fashioned type where you can roam round and find stuff for yourself) and have a look at a few VWs and Audis, or anything else, to see what else looks compatible.
If all else fails, have you got the old one ? If so, it might be possible to have the ends fitted to another cable. OR - see if you can find an AA or RAC man, and ask nicely if they have any temporary end fittings. I called the AA out once because my sister's LHD porsche 924 had a broken clutch cable. Matey turned up on a motorbike and virtually made up a new temporary cable for me at the side of the road. It got the car home, and then to my mate's workshop, where I modified a new one so it couldn't snap again (it had plastic ends which were the weak point, particularly on sthis car which had a very stiff clutch mechanism). I fabricated some metal ends so they couldn't snap like the plastic ones would have done.
